The hints in this application note are intended to show you how you can make more accurate measurements with your frequency counter and how you can make these measurements faster and more easily. No matter which frequency counter you use, you should be able to apply the hints in this application note to your measurement application. To illustrate the concepts, we have used Agilent 53131A, 53132A and 53181A frequency counters.
