1 Broad range of measurement capabilities facilitate device evaluation We can help you: ■ Evaluate solar cell IV characteristics using any of Agilent’s precision SMU products. This gives you great flexibility to select a solution that meets your exact needs. ■ Perform CV and Cf characterizations using the B1500A’s and B1505A’s MFCMU module. This allows you to determine important parameters such as carrier density, defect density and charge traps. ■ Make high-speed time domain measurements using the B1500A’s WGFMU module. This enables you to evaluate solar cell transient characteristics without the need for any other external instruments. ■ Streamline your data analysis using EasyEXPERT’s intuitive and easy-to-use test environment.
