POWR-GARD Protection Relays an
消耗积分:3 | 格式:rar | 大小:548 | 2010-08-26
分享资料个
Description
The PGR-6100 Ground-Fault & Insulation Relay is designed
to provide basic protection for a motor, including ground-
fault protection and insulation monitoring. The fact that the
PGR-6100 has predictive as well as protective capabilities
makes it unique. The ground-fault current and insulation
resistance can be monitored using two separate meters.
Two separate alarm contacts are also provided.
评论(0)
发评论
下载排行榜
