L7810C三端稳压器数据手册pdf
消耗积分:1 | 格式:pdf | 大小:1803KB | 2018-02-28
LIULIU1234567
分享资料个
DESCRIPTION
The L7800 series of three-terminal positive regulators is available in TO-220, TO-220FP, TO-220FM, TO-3 and D2PAK packages and several fixed output voltages, making it useful in a wide range of applications. These regulators can provide local on-card regulation, eliminating the distribution problems associated with single point regulation. Each type employs internal current limiting, thermal shut-down and safe area protection, making it essentially indestructible. If adequate heat sinking is provided, they can deliver over 1A output current. Although designed primarily as fixed voltage regulators, these devices can be used with external components to obtain adjustable voltage and currents.
评论(0)
发评论
下载排行榜
