The REF200 combines three circuit building-blocks on a single monolithic chip—two 100µA current sources and a current mirror. The sections are dielectrically isolated, making them completely independent. Also, since the current sources are two-terminal devices, they can be used equally well as current sinks. The performance of each section is individually measured and laser-trimmed to achieve high accuracy at low cost. The sections can be pin-strapped for currents of 50µA,100µA, 200µA, 300µA or 400µA. External circuitry can be used to obtain virtually any current. These and many other circuit techniques are shown in the Applications section of this Data Sheet. The REF200 is available in plastic 8-pin mini-DIP and SOIC packages.The REF200 is available in plastic 8-pin mini-DIP and SOIC packages.
