TL431B-Q1/TL431A-Q1,pdf (Adjus
消耗积分:3 | 格式:rar | 大小:422 | 2010-09-24
分享资料个
The TL431-Q1 is a three-terminal adjustable shunt regulator with specified thermal stability over applicable automotive temperature ranges. The output voltage can be set to any value between Vref (approximately 2.5 V) and 36 V, with two external resistors. This device has a typical output impedance of 0.2 . Active output circuitry provides a sharp turn-on characteristic, making this device an excellent replacement for Zener diodes in many applications, such as onboard regulation, adjustable power supplies, and switching power supplies.
评论(0)
发评论
下载排行榜
