DG2016/DG2026 pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-09-29
王越建
分享资料个
DESCRIPTION
The DG2016/DG2026 are monolithic CMOS dual
single-pole/double-throw (SPDT) analog switchs. They are
specifically designed for low-voltage, high bandwidth
applications.
The DG2016/DG2026’s on-resistance (3 Ω at 2.7 V),
matching and flatness are guaranteed over the entire analog
voltage range. Wide dynamic performance is achieved with
better than - 80 dB for both cross-talk and off-isolation at
1 MHz.
Both SPDT’s operate with independent control logic,
conduct equally well in both directions and block signals up
to the power supply level when off. Break-before-make is
guaranteed.
With fast switching speeds, low on-resistance, high
bandwidth, and low charge injection, the DG2016/DG2026
are ideally suited for audio and video switching with high
linearity.
Built on Vishay Siliconix’s low voltage CMOS technology, the
DG2016/DG2026 contain an epitaxial layer which prevents
latch-up.
评论(0)
发评论
下载排行榜
