The LM20, LM45, LM50, LM60, LM61, and LM62 are analog output temperature sensors. They have various output voltage slopes (6.25mV/°C to 17mV/°C) and power supply voltage ranges (2.4V to 10V).The LM20 is the smallest, lowest power consumption analog output temperature sensor National Semiconductor has released. The LM70 and LM74 are MICROWIRE/SPI compatible digital temperature sensors. The LM70 has a resolution of 0.125°C while the LM74 has a resolution of 0.625°C. The LM74 is the most accurate of the two with an accuracy better than ±1.25°C. The LM75 is National’s first digital output temperature sensor, released several years ago.
