基于塑料光纤的高压隔离通信接口设计
消耗积分:5 | 格式:rar | 大小:865 | 2010-11-22
h1708587244.0670
分享资料个
 通过比较各种隔离数字通信的特点和应用范围,指出塑料光纤在隔离数字通信中的优势。使用已经标准化的TOSLINK接口,有利于节省硬件开发成本和简化设计难度。给出了塑料光纤的硬件驱动电路,说明设计过程中的注意事项,对光收发模块的电压特性和频率特性进行全面试验,并给出SPI口使用塑料光纤隔离通信的典型应用电路图。试验结果表明,该设计可为电力现场、电力电子及仪器仪表的设计提供参考。
Abstract:
 y comparing characteristics and applications area of various isolated digital communications, this article indicates advantages of plastic optical fiber in isolated digital communications. Using the standardized TOSLINK interface, it helps to control costs and difficulty in hardware development and design. Then it gives the hardware driver circuit of plastic optical fiber module, explains the noticed details in design process, gives results on the basis of the optical transceiver module voltage characteristics and frequency characteristics tests. Finally,it gives typical application circuit of the SPI communication port by using plastic optical fiber isolation .The results show that this design can be referenced for the power field, power electronics and instrumentation design.
评论(0)
发评论
下载排行榜
