为了在工业生产及过程控制中准确测量温度,设计了一种基于低功耗MSP430单片机的数字温度计。整个系统通过单片机MSP430F1121A控制DS18B20读取温度,采用数码管显示,温度传感器DS18B20与单片机之间通过串口进行数据传输。MSP430系列单片机具有超低功耗,且外围的整合性高,DS18B20只需一个端口即可实现数据通信,连接方便。通过多次实验证明,该系统的测试结果与实际环境温度一致,除了具有接口电路简单、测量精度高、误差小、可靠性高等特点外,其低成本、低功耗的特点使其拥有更广阔的应用前景。
- Abstract:
- In order to obtain accurate measuring temperature in industrial production and process control, a digital thermometer based on MSP430 MCU is designed. The system uses MSP430F1121A MCU to control DS18B20, and gets the temperature data, which is displayed on the LED. The temperature sensor DS18B20 and MCU transmit data through serial communication. MSP430 series has ultra-low power and high integration, DS18B20 only needs one port to achieve data communication. Through many experimental results prove, this system is consistent with actual environment temperature. The system has characteristics of interface circuit simple, high measuring accuracy, minor error, high reliability, besides, the characteristics of low cost and low power make it having vaster application prospect.
