基于控制回路补偿参考电流的检测方法,设计出了有源电力滤波器的主电路和控制电路。其中检测部分采用了基于信号时域正交特性的参考指令电流优化PWM检测方法,并通过锁相倍频电路和EPROM单元来控制高速模拟开关,电路简单,便于实现。
- Abstract:
- Based on a method of measuring compensating reference current for control loop, the main circuit and control circuit of the active power filter are designed. The tested part adopts a referenced command current optimize PWM detecting method based on signal’s time domain vertical property, and high speed simulating switch is controlled by frequency multiplication phase-locked circuit and EPROM unit. The circuit configuration is simple and easy to implement.
