基于幅移键控技术ASK(Amplitude-Shift Keying),以C8051F340单片机作为监测终端控制器,C8051F330D单片机作为探测节点控制器,采用半双工的通信方式,通过监控终端和探测节点的无线收发电路,实现数据的双向无线传输。收发电路采用直径为0.8 mm的漆包线自行绕制成圆形空心线圈天线,天线直径为(3.4±0.3)cm。试验表明,探测节点与监测终端的通信距离为24 cm,通过桥接方式,节点收发功率为102 mW时,节点间的通信距离可达20 cm。与传统无线收发模块相比,该无线收发电路在受体积、功耗、成本限制的场合有广阔的应用前景。
- Abstract:
- Based on ASK technology and with the C8051F340 and C8051F330D MCU as the controller, using half-duplex communication mode, this paper achieves bi-directional data transfer. Transceiver circuit constituted by enameled wire which diameter is 0.8mm and wound into a diameter (3.4±0.3) cm circular hollow coil antenna. Tests show that the communication distance between detection and monitoring of the terminal is 24cm,the distance is up to 20cm between two nodes when using the manner of bridging and the node transceiver power is 102mW. Compared with the conventional wireless transceiver modules, the circuit has wide application prospect in small size, low cost and low power consumption and other characteristics.
