基于C8051F340的数据采集器设计
消耗积分:10 | 格式:rar | 大小:9917 | 2010-12-14
李丽
分享资料个
针对众多低成本数据采集需求,采用带有片上USB控制器和D/A转换器的混合信号微处理器C8051F340,设计了一款可通过USB接口和LabVIEW图形用户界面实现与PC机联机的数据采集器,同时借助系统的SD卡存储独立实现现场长时间采集数据。该数据采集器成本低,结构简单,体积小,已成功用于工业现场。
Abstract:
 Aiming at the need of low cost data acquisition, a data acquisition device is designed based on C8051F340 which is a mixed-signal microcontroller and integrates USB controller and A/D controller on a chip.The data acquisition device which can combine with PC by USB interface and LabVIEW graphical user interface,can realize data acquisition. At the same time,it can be solely run a long time in virtue of SD card in field.The date aequisition device features low cost,simple structure and little sharp, and it has been used in industry field.
评论(7)
发评论
李加杰 2015-11-18
0 回复 举报
谢谢,楼主,下来看看 收起回复
lyl420819 2015-07-04
0 回复 举报
谢谢楼主了,下载学习。 收起回复
全部评论
下载排行榜
全部7条评论
