在汽车发动机起动时,若发动机起动后起动机不能及时断电,将会烧毁起动机或损坏飞轮齿环;若变速器不在空档位置起动,则起动机的瞬间动力将使汽车位移,还可能引起交通事故和人身安全。为此介绍一种利用NXP P89LPC901单片机控制的汽车起动保护控制器,通过检测汽车起动开关、变速箱档位、发动机转速,实现对汽车发动机起动过程检测和保护。起动保护控制器在发动机起动过程中通过采用逐个关闭打开负载系统,解决汽车发动机过程中因起动电流大而对汽车电源的冲击影响,延长了电瓶寿命。
- Abstract:
- When the automotive engine is started, the engine start motor and flywheel gear may be damaged, even traffic accidents and personal safeties may be caused by wrong operation or other factors.In order to ensure the automotive engine can be started normally and safely,it is necessary that the protecting measures and methods are considered in the automotive electrical control system.This paper introduces a kind of the automotive engine starting protect controller based on NXP P89LPC901 MCU.The controller can protect the engine starting process by detecting the starter key switch,transmission stall and engine speed.Through the use of close and open load system,the controller can solve the impact on automotive power because of the high-current load in the process of the automobile engine starting, and extend battery life.
