移动商务应用系统集成架构
消耗积分:0 | 格式:rar | 大小:478 | 2010-12-22
弈人
分享资料个
以Java技术规范为核心,结合强大的Web Service,Hibernate,Spring和Oracle技术,提出一种新型移动商务应用系统集成架构,并得到了实际验证。实践证明,这种新型技术架构维护简单,扩展容易,代码重复利用率高,模块之间实现了松耦合。因此它是一项值得推广应用的新型技术架构。
Abstract:
 This paper put forward a new integrated structural frame of the mobile commercial affairs application system which combines with the powerful Web Service,Hibernate,Spring and Oracle,according to the Java technology standards.The system has been tested in practice,and it is proved that the new frame is simply maintained,easily expanded,and its code is repeatedly applied,and is realized the loose coupling between modules.So the new frame must be widely applied.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
