NAT-PT技术在IPv4和IPv6互联中的实现
消耗积分:3 | 格式:rar | 大小:396 | 2010-12-28
笑尽往事
分享资料个
介绍NAT鄄PT及与其相关的网间协议转换技术,采用NAT鄄PT技术设计IPv4/IPv6转换网关。通过该网关在实际网络环境中运行,测试NAT鄄PT对UDP协议和TCP协议的翻译,最终实现IPv4和IPv6之间的双向通信功能,满足网络高速发展的需求。
Abstract:
 This paper introduces NAT-PT technology and its related IP conversion.Adopting NAT-PT technology to design IPv4/IPv6transition Gateway,it tests on the UDP protocol and TCP protocol translation by using the gateway in the actual network operation.Finally,this technology achieves communication function between IPv4and IPv6,and meets the requirement of network rapid development.
评论(0)
发评论
下载排行榜
