SMART Transmitter Power Supply KFD2-STV5-Ex1-1
型号: KFD2-STV5-Ex1-1
--- 产品参数 ---
查看更多参数
公司logo
巨匠机械
98內容 |  3.1w浏览量  |  35粉丝
--- 产品详情 ---
  • 1-channel isolated barrier
  • 24 V DC supply (Power Rail)
  • Input 2-wire and 3-wire SMART transmitters and 2-wire SMART current sources
  • Output 1 V ... 5 V
  • Terminals with test points
  • SIL 2 (SC 3) acc. to IEC/EN 61508
提示:以下是本篇文章正文内容,下面案例可供参考
一、产品描述
参数表节选:的技术参数  KFD2-STV5-Ex1-1
General specifications
Signal typeAnalog input
Functional safety related parameters
Safety Integrity Level (SIL)SIL 2
Systematic capability (SC)SC 3
Supply
ConnectionPower Rail or terminals 14+, 15-
Rated voltage18 ... 30 V DC
Ripplewithin the supply tolerance
Power dissipation≤ 1 W at maximum load
Power consumption≤ 1.6 W at maximum load
Input
Connection sidefield side
Connectionterminals 1+, 2-, 3
Input signal4 ... 20 mA
Open circuit voltage/short-circuit currentterminals 1+, 3: 23 V / 25 mA
Input resistancemax. 265 Ω terminals 2-, 3 , max. 330 Ω terminals 1+, 3
Available voltage≥ 16 V at 20 mA ; ≥ 20 V at 4 mA , terminals 1+, 3
Output
Connection sidecontrol side
Connectionterminals 7-, 8+, 9+
Output signal1 ... 5 V
Ripplemax. 12.5 mV
Output resistance250 Ω
Transfer characteristics
Deviationat 20 °C (68 °F)
≤ 5 mV incl. calibration, linearity, hysteresis, loads and fluctuations of supply voltage
 Influence of ambient temperature≤ 20 ppm/K
Frequency rangefield side into the control side: bandwidth with 0.5 Vpp signal 0 ... 7.5 kHz (-3 dB)
control side into the field side: bandwidth with 0.5 Vpp signal 0.3 ... 7.5 kHz (-3 dB)
Settling time200 µs
Rise time/fall time100 µs
Galvanic isolation
Input/Outputsafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
Input/power supplysafe electrical isolation acc. to IEC/EN 60079-11, voltage peak value 375 V
Output/power supplyfunctional insulation, rated insulation voltage 50 V AC
Indicators/settings
Display elementsLED
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 61326-1:2013 (industrial locations)
Conformity
Electromagnetic compatibilityNE 21:2012
EN 61326-3-2:2008
Degree of protectionIEC 60529:2001
Protection against electrical shockUL 61010-1:2012
Ambient conditions
Ambient temperature-20 ... 70 °C (-4 ... 158 °F)
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 150 g
Dimensions20 x 124 x 115 mm (0.8 x 4.9 x 4.5 inch) (W x H x D) , housing type B2
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
Data for application in connection with hazardous areas
EU-type examination certificateCML 17 ATEX 2029X
 Marking
Ex-Hexagon
II (1)G [Ex ia Ga] IIC
Ex-Hexagon
II (1)D [Ex ia Da] IIIC
Ex-Hexagon
I (M1) [Ex ia Ma] I
 Input[Ex ia Ga] IIC, [Ex ia Da] IIIC, [Ex ia Ma] I
Supply
 Maximum safe voltage250 V (Attention! The rated voltage can be lower.)
Equipmentterminals 1+, 3-
 Voltage26.2 V
 Voltage27.25 V
 Current93 mA
 Power634 mW
Equipmentterminals 2-, 3
 Voltage30 V
 Current115 mA
 Powermax 1 W
 Voltage2 V
 Current8.5 mA
 Power4.3 mW
Equipmentterminals 1+, 2 / 3-
 Voltage26.2 V
 Voltage27.25 V
 Current115 mA
 Power784 mW
CertificateCML 17 ATEX 3028X
 Marking
Ex-Hexagon
II 3G Ex ec IIC T4 Gc
Galvanic isolation
 Input/Outputsafe electrical isolation acc. to IEC/EN 60079-11:2007, voltage peak value 375 V
 Input/power supplysafe electrical isolation acc. to IEC/EN 60079-11:2007, voltage peak value 375 V
 Directive 2014/34/EUEN IEC 60079-0:2018 , EN 60079-7:2015+A1:2018 , EN 60079-11:2012
International approvals
UL approvalE106378
 Control drawing116-0439 (cULus)
IECEx approval
 IECEx certificateIECEx CML 17.0015X
 IECEx marking[Ex ia Ga] IIC , [Ex ia Da] IIIC , [Ex ia Ma] I
Ex ec IIC T4 Gc
General information
Supplementary informationObserve the certificates, declarations of conformity, instruction manuals, and manuals where applicable. For information see www.pepperl-fuchs.com.
二、应用领域
示例:
• 工业控制领域:工业、控制设备美。
三、应用电路图
示例:
总结
提示:这里对文章进行总结:
例如:以上就是今天要讲的内容,本文仅仅简单介绍了XX产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
