Homebridge Pi恒温器插件
消耗积分:0 | 格式:zip | 大小:0.01 MB | 2022-04-21
张昂笙
分享资料个
授权协议 Readme
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
Homebridge Pi Thermostat Plugin
This is a homebridge plugin to make a Raspberry Pi connected with a Relay Board and DHT22 Temperature and Humidity Sensor into a smart thermostat that can be controlled via the Home app on iOS using Homekit.
Guide
For those who want to create their own thermostat using Raspberry Pi, here is a blog post that goes through the details of where to buy the parts, how to assemble it and what software to install to get this to work.
Installation
  • Install nodejs and other dependencies for homebridge to work
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejs libavahi-compat-libdnssd-dev
  • Install BCM2835 for temperature sensor to work
wget http://www.airspayce.com/mikem/bcm2835/bcm2835-1.52.tar.gz
tar zxvf bcm2835-1.52.tar.gz
cd bcm2835-1.52
./configure && make && sudo make check && sudo make install
  • Install homebridge and this plugin
sudo npm install -g --unsafe-perm homebridge homebridge-pi-thermostat
  • Add the accessory config to your homebridge config file located at this path ~/.homebridge/config.json.
  "bridge": {
    "name": "Homebridge",
    "username": "CC:22:3D:E3:CE:30",
    "port": 51826,
    "pin": "031-45-154"
  "description": "",
  "accessories": [
      "accessory": "Thermostat",
      "name": "Pi Thermostat",
      "fanRelayPin": 26,
      "heatRelayPin": 21,
      "coolRelayPin": 20,
      "temperatureSensorPin": 4,
      "minimumOnOffTime": 120000,
      "blowerTurnOffTime": 80000,
      "startDelay": 10000,
      "temperatureCheckInterval": 10000
  "platforms": []
  • Start it up by running homebridge command.
Configuration
Relay Pins
You can change the pin to turn on and off the relay switch for the Fan, Heat and Cool setting.
"fanRelayPin": 26,
"heatRelayPin": 21,
"coolRelayPin": 20,
Temperature Sensor Pin
You also can change the pin for the DHT22 temperature sensor.
Timing
The system has a minimum on off time which is in miliseconds and is the minimum time it keeps the Heat or Cool turned on and off so that it does not damage the heating or cooling system by turning on and off very quickly.
The system also has a blowerTurnOffTime which is the time it takes to turn off the blower after Heat or Cool is turned off.
The interval for checking the temperature of the room can also be set and defaults to 10 seconds.
Screenshots
评论(0)
发评论
下载排行榜
