Homebridge GPIO WiringPi平台插件
消耗积分:0 | 格式:zip | 大小:0.01 MB | 2022-04-20
王桂兰
分享资料个
授权协议 Readme
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
Homebridge GPIO WiringPi - Platform Plugin
WORK IN PROGRESS
Please report issues at https://github.com/rsg98/homebridge-gpio-wpi2/issues
Supports triggering General Purpose Input Output (GPIO) pins on the Raspberry Pi.
Uses wiringPi as a back end to give non-root access to GPIO.
Requirements
This version of the plugin expects WiringPi itself to already be installed - see the documentation for node-wiring-pi for more details, or just follow the instructions below for Raspbian.
Installation
  1. Install the wiringpi package using sudo apt-get install wiringpi
  2. Install Homebridge using sudo npm install -g homebridge
  3. Install this plugin sudo npm install homebridge-gpio-wpi2
  4. Update your configuration file - see config-platform-sample.json in this repo
  5. Make sure your homebridge user is in the gpio group.
 $ sudo usermod -G gpio homebridge
Configuration
The pin numbers used in this config file are the BCM pin numbers, not the physical pins or WiringPi pin numbers.
You can run gpio readall to generate a table showing how the BCM pin numbers map to the physical pins, which varies between models of Raspberry Pi.
	"bridge": {
		"name": "Homebridge",
		"username": "CC:22:3D:E3:CE:30",
		"port": 51826,
		"pin": "031-45-155"
    "description": "This is an example configuration file with one fake accessory and one fake platform.",
    "platforms": [{
          "platform" : "WiringPiPlatform",
          "name" : "Pi GPIO (WiringPi)",
          "overrideCache" : "true",
          "autoExport" : "true",
          "gpiopins" : [{
	  	"type":"Switch",
		"name" : "GPIO2",
                "pin"  : 27,
                "enabled" : "true",
                "mode" : "out",
                "pull" : "down",
                "inverted" : "false",
                "duration" : 0,
                "polling" : "true"
		"type":"MotionSensor",
                "name" : "GPIO3",
                "pin"  : 22,
                "enabled" : "true",
                "mode" : "in",
                "pull" : "down",
                "duration" : 0
Platform Config Items
Config Item Valid Values Description
platform WiringPiPlatform Must be set to this value to initialise this plugin
name string What you want this platform to be called (appears in the logs and such like)
overrideCache true / false Homebridge will cache all your accessories - setting this to true will ignore the cached value (direction, mode, etc.) and read them direcly from your config file
autoExport true / false As long as your homebridge user has permission (i.e. is a member of the gpio group), setting this to true will automatically export the pins via sysfs, meaning you don't need a set-gpio.sh script
Pin Config Items
"type" "string" Type of device connected to GPIO. Set to "Switch" for "out" pin mode, or one of "ContactSensor", "LeakSensor", "MotionSensor", "OccupancySensor", or "SmokeSensor" for "in" pin mode
name string Initial display name for the PIN accessory - can be renamed in HomeKit app (e.g. Home)
pin number The BCM pin number - see Pin Configuration below
enabled true / false Whether you want the module to publish this pin as an accessory
mode out / in Mode the pin should operate in
pull up / down / off Configuration for the built in Pi pull up resistor
inverted true / false Reverse the behaviour of the GPIO pin (0 is on, 1 is off)
duration number Pin will turn off after this number of miliseconds
polling true / false Whether Homebridge should periodically check the status of the pin (perhaps it's being set by something external to homebridge)
Pin Configuration
If you don't use the autoExport option above, you'll need to manually configure the relevant GPIO pins using the gpio utility included with wiringPi.
This is not necessary if you use autoExport and your homebridge user is a member of the gpio group.
$ gpio readall
 +-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |  OUT | 0 |  3 || 4  |   |      | 5V      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 1 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |  OUT | 0 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
 |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
 |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
 |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
 |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
The pin number specified in the config.json file is the BCM pin number in this table.
To set up the pins correctly, this module includes a make-gpio-script script, which will generate a set-gpio.sh. You should run set-gpio.sh before starting Homebridge so that all the pins are configured. If you start Homebridge using systemd, you can add set-gpio.sh as a ExecStartPre command in the homebridge.service file
$ node make-gpio-script config.json set-gpio.sh
The gpio tool is setuid root, so this script should be run as the user that runs Homebridge.
Troubleshooting
Homebridge reports no errors, but nothing is switched on or off
Check the permissions in /sys/class/gpio/gpioXX - autoExport option should have created all these properly, if your Homebridge user account has the right permissions (i.e. is a member of the gpio group)
If you are not using autoExport, you should run the set-gpio.sh script as the homebridge user (see section above to generate this script):
Licence
(The MIT License)
Copyright (c) 2016 Richard Grime richard.grime@gmail.com
Original Project Copyright (c) 2016 James Blanksby james@blanks.by
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
评论(0)
发评论
下载排行榜
