homebridge miio平台插件
消耗积分:0 | 格式:zip | 大小:0.01 MB | 2022-04-20
生龙活虎3
分享资料个
授权协议 Readme
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
homebridge-miio is a platform plugin for homebridge which lets you switch Xiaomi Power Plugs on and off using Homekit apps and Siri.
Note: this plugin works for me, but i'm not motivated to maintain it's compatibility with other devices or firmware versions that i'm not using. If you have problems, please send some pull requests! Opening an issue isn't enough. I'm not "upgrading" my devices to incompatible firmware versions just to debug issues for you.
It seems very reliable now, and should coexist happily with other Xiaomi home automation ecosystem plugins. Eventually it would be nice to support some other device types, if people who have those devices want to do pull requests, or donate hardware, it'd surely be welcomed. You don't need to configure anything, just install the platform plugin with npm install -g homebridge-miio. devices on the same subnet as your homebridge server will be discovered at launch and every half hour after that, and supported devices will be polled for changes occasionally to keep things responsive.
Here's an example homebridge config file, you could use to tweak the default settings. Numbers are presented in seconds. If you choose to disable pollChanges you may see some inconsistency if you also control your miIO devices via the Mi Home app (including via Mi Home app timers).
Note that currently only the WiFi plugs are supported, not the gateway-based ones operating over Zigbee, though this is likely to change in the future.
  "bridge": {
    "name": "TestBridge",
    "username": "CC:22:3D:E3:CE:33",
    "port": 51826,
    "pin": "031-45-154"
  "description": "Test Bridge",
  "accessories": [],
  "platforms": [
      "platform" : "XiaomiMiio",
      "name" : "XiaomiMiio",
      "pollChanges": true,
      "pollInterval": 15,
      "searchInterval": 1800
评论(0)
发评论
下载排行榜
