Homebridge插件集成Shinobi
消耗积分:0 | 格式:zip | 大小:0.04 MB | 2022-04-21
王英
分享资料个
授权协议 MIT License
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
homebridge-shinobi
A Homebridge plugin integrating Shinobi for motion detector cameras
Installation
  1. Install Homebridge using: npm install -g homebridge
  2. Install this plugin: npm install -g homebridge-shinobi
  3. Update your configuration file. See a sample config.json snippet below.
  4. Ensure ffmpeg is installed and on the path.
NOTE: Currently there is no support for streaming audio from a camera.
Configuration
Example config.json entry:
"platforms": [
        "platform": "Shinobi",
        "shinobi_api": "http://x.x.x.x:8080",
        "api_key": "xxx",
        "group_key": "house",
        "monitors": [
                "monitor_id": "front"
                "monitor_id": "rear"
        "web_hook_port": "8443",
        "https_key_path": "/cert/privkey.pem",
        "https_cert_path": "/cert/fullchain.pem"
Where:
  • shinobi_api is the base URL for the Shinobi API
  • api_key is the Shinobi API key (configured in the Shinobi dashboard API menu)
  • group_key is a Shinobi group key
  • monitors contains a list of monitors consisting of:
    • monitor_id
  • web_hook_port is the port that the platform should listen on for motion event webhooks from Shinobi
If both https_key_path and https_cert_path are configured to point at HTTPS key and cert files available on the Homebridge server the webhook server will be hosted on HTTPS.
Shinobi Integration
The specified shinobi_api and api_key will be used to make all Shinobi API requests.
Each of the specified monitor IDs will be used with the specified group_key to add a new accessory to the platform consistent of a Motion Sensor service and camera.
When viewing video, the plugin will use the information returned from the API for a specific Monitor to determine the source video stream configured. FFmpeg is used to stream directly from the camera and forward to HomeKit. If possible, the video will not be re-encoded.
Snapshot images for each Monitor are simply pulled from the Shinobi API.
A webhook URL should be configured for each Monitor within the Shinobi 'Global Detector Settings' with the following format:
http[s]://>:?mid=&group=
For example, assuming the Homebridge instance is available at 192.168.1.10 and using the above sample config, the two Monitors front and rear would have webhook URLs configured as:
https://192.168.1.10:8443?mid=front&group=house
and
https://192.168.1.10:8443?mid=rear&group=house
Help etc.
If you have a query or problem, raise an issue in GitHub, or better yet submit a PR!
评论(0)
发评论
下载排行榜
