GC5330,pdf _5330 Wideband Digital Tx and Rx Processor
消耗积分:0 | 格式:pdf | 大小:488 KB | 2011-06-13
dplion
分享资料个
GC5330说明:The GC533x is a wideband transmit and receive signal processor that includes digital downconverter / upconverter (DDUC), transmit, receive, and capture buffer blocks. The transmit path includes crest factor reduction (CFR), digital predistortion (DPD) and associated feedback path, complex equalization, and bulk upconversion.
The receive path includes wideband and narrowband automatic gain control (AGC), bulk downconversion, complex equalization, and I/Q imbalance correction.
The DDUC section consists of four identical DDUC blocks, each supporting up to 12 channels. Each channel has independent fractional resamplers and NCOs to enable flexible carrier configurations. Multi-mode/multi-standard operation can be supported by configuring the individual DDUC blocks to different filtering and oversampling scenarios.
View full Description in Datasheet
GC5330特性:Integrated Transmit and Receive Digital IF Solution
Up to 4 TX, 8 RX, Plus DPD Feedback
TX-Transmit Includes DUC, CFR, DPD, TX Equalizer,
and Bulk Upconverter
62-MHz TX Signal Bandwidth With Fifth-Order DPD Correction
CFR: 6-dB PAR for WCDMA, 7-db LTE Signals With
EVM Meeting 3GPP Specs; Configurable for All
Major Wireless Infrastructure Standards
DPD: Memory Compensation, Typical ACLR Improvement of
20 dB or More
RX-Receive Includes DC-Offset Cancellation, Front-End and
Back-End AGC, Bulk Downconverter, RX Equalizer, I/Q
Imbalance Correction, DDC
4 DDUCs, 1–12 Channels per DDUC, Each DDUC Can Be
Programmed to TX or RX, at a Common Resampler Rate –
Multimode Support
Seamless Interface to TI High-Speed Data Converters
4 TX Aggregate Output to DACs up to 930 MSPS Complex
8 RX Aggregate Input From ADCs up to 1.24 GSPS Real
Supports Envelope Tracking Techniques
16-Tap (Complex) RX Equalizers
Two 4K Complex Word Capture Buffers for Signal Analysis,
Adaptive Filtering, and DPD Algorithms
TMS320C6748 DPD Optimization Software
1.1-V Core, 3.3-V I/O CMOS, 1.8-V I/O LVDS
Power Consumption, 3.5 W Typical
484-Ball TE-PBGA Package, 23 mm × 23 mm
APPLICATIONS
Multi-Standard Base Stations
评论(0)
发评论
下载排行榜
