雪崩光电二极管的偏置电压和电流检测电路
消耗积分:0 | 格式:pdf | 大小:991 KB | 2012-01-05
分享资料个
Avalanche photodiodes (APDs) are widely utilized in laserbased fiberoptic systems to convert optical data intoelectrical form. The APD is usually packaged with a signalconditioning amplifier in a small module. An APD receivermodule and attendant circuitry appears in Figure 1. TheAPD module (figure right) contains the APD and a transimpedance(e.g., current-to-voltage) amplifier. An opticalport permits interfacing fiberoptic cable to the APD’sphotosensitive portion. The module’s compact constructionfacilitates a direct, low loss connection between theAPD and the amplifier, necessary because of the extremelyhigh speed data rates involved
评论(0)
发评论
下载排行榜
