MAX5723,MAX5724,MAX5725 oltage-output digital-to-analog converters
消耗积分:0 | 格式:pdf | 大小:2.32 MB | 2012-04-13
分享资料个
The MAX5723/MAX5724/MAX5725 8-channel, low-power,8-/10-/12-bit, voltage-output digital-to-analog converters(DACs) include output buffers and an internal 3ppm/°Creference that is selectable to be 2.048V, 2.500V, or4.096V. The MAX5723/MAX5724/MAX5725 accept awide supply voltage range of 2.7V to 5.5V with extremelylow power (6mW) consumption to accommodate mostlow-voltage applications. A precision external referenceinput allows rail-to-rail operation and presents a 100kI(typ) load to an external reference.
评论(0)
发评论
下载排行榜
