12位Low Power四路电压输出DAC与串行接口MAX5742
消耗积分:0 | 格式:rar | 大小:0.66 MB | 2017-09-25
分享资料个
  The MAX5742 quad, 12-bit, low-power, buffered voltage-output, digital-to-analog converter (DAC) is packaged in a space-saving 10-pin µMAX package (5mm ✕ 3mm)。 The wide supply voltage range of +2.7V to +5.5V and 229µA supply current accommodates lowpower and low-voltage applications. DAC outputs employ on-chip precision output amplifiers that swing Rail-to-Rail®。 The MAX5742’s reference input accepts a voltage range from 0 to VDD. In power-down the reference input is high impedance, further reducing the system’s total power consumption. The 20MHz, 3-wire SPI™, QSPI™, MICROWIRE™ and DSP-compatible serial interface saves board space and reduces the complexity of opto- and transformerisolated applications. The MAX5742 on-chip power-on reset (POR) circuit resets the DAC outputs to zero and loads the output with a 100kΩ resistor to ground. This provides additional safety for applications that drive valves or other transducers that need to be off on power-up. The MAX5742’s software-controlled powerdown reduces supply current to less than 0.3µA and provides software-selectable output loads (1kΩ, 100kΩ, or high impedance) while in power-down. The MAX5742 is specified over the -40°C to +125°C automotive temperature range.
评论(1)
发评论
严天宇 2021-09-15
0 回复 举报
下载看看 收起回复
下载排行榜
全部1条评论
