在精密仪用放大器(IA)中增加一个CMOS运算放大器INA1
消耗积分:0 | 格式:rar | 大小:29 | 2009-06-06
分享资料个
You can combine a precision instrumentation amplifier (IA)
and an inexpensive CMOS op amp to get the best of two
worlds—the precision of a bipolar IA and 5V single-supply
operation. Using the INA131 gives 50mV max voltage
offset, 0.25mV/°C max offset drift, and 110dB min commonmode
rejection. How close the output swings to the power
supply rail depends on which “rail-to-rail” CMOS op amp
you use. With a TI TL2272 you can expect the output to
swing within 100mV of the rails
评论(0)
发评论
下载排行榜
