U14 BQ24195LRGE资料
消耗积分:1 | 格式:pdf | 大小:2281KB | 2014-11-24
wmh1990515
分享资料个
The bq24195L, bq24195 are highly-integrated switch-mode battery charge management and system power path management devices for single cell Li-Ion and Li-polymer battery in a wide range of power bank, tablet and other portable devices. Its low impedance power path optimizes switch-mode operation efficiency, reduces battery charging time and extends battery life during discharging phase。 The I 2C serial interface with charging and system settings makes the device a truly flexible solution。
评论(2)
发评论
swjtu@wangfei 2016-04-22
0 回复 举报
可以得 收起回复
PRINCEMENG 2016-04-08
0 回复 举报
看看 收起回复
下载排行榜
全部2条评论
