DS90CF363B,pdf datasheet (+3.3
消耗积分:0 | 格式:rar | 大小:558 | 2009-10-14
张国厚
分享资料个
The DS90CF363B transmitter converts 21 bits of CMOS/TTL
data into three LVDS (Low Voltage Differential Signaling)
data streams. A phase-locked transmit clock is transmitted in
parallel with the data streams over a fourth LVDS link. Every
cycle of the transmit clock 21 bits of input data are sampled
and transmitted. At a transmit clock frequency of 65 MHz, 18
bits of RGB data and 3 bits of LCD timing and control data
(FPLINE, FPFRAME, DRDY) are transmitted at a rate of 455
Mbps per LVDS data channel. Using a 65 MHz clock, the
data throughput is 170 Mbytes/sec. The DS90CF363B is
fixed as a Falling edge strobe transmitter and will interoperate
with a Falling edge strobe Receiver (DS90CF366) without
any translation logic.
评论(0)
发评论
下载排行榜
