DS-000184-ICM-20600-v1.0
消耗积分:1 | 格式:pdf | 大小:2212KB | 2017-03-29
Mr.Han
分享资料个
Low-Power, High-Performance Integrated 6-Axis MEMS MotionTracking
  The ICM-20600 is a 6-axis MotionTracking device that combines a 3-axis gyroscope, 3-axis accelerometer, in a small 2.5 mm x 3 mm x 0.91 mm (14-pin LGA) package.  High performance specs o Gyroscope sensitivity error: ±1% o Gyroscope noise: ±4 mdps/Hz o Accelerometer noise: 100 µg/Hz  Includes 1 KB FIFO to reduce traffic on the serial bus interface, and reduce power consumption by allowing the system processor to burst read sensor data and then go into a low-power mode  EIS FSYNC support ICM-20600 includes on-chip 16-bit ADCs, programmable digital filters, an embedded temperature sensor, and programmable interrupts. The device features an operating voltage range down to 1.71V. Communication ports include I 2C and high speed SPI at 10 MHz.
评论(0)
发评论
下载排行榜
