padslayout_ref英文资料
消耗积分:0 | 格式:pdf | 大小:25346KB | 2017-04-21
飒然jrb199503
分享资料个
padslayout_ref
  Setup all design rules, including clearance, routing, high-speed and others, within the design rule dialog boxes. To setup design rules: 1. Setup menu 》 Design Rules. 2. Click the Default button. Result: The Default Rules dialog box appears. Use this dialog box to select the type of default rule to enter. See the table below for more information. 3. Click the Clearance button to enter default clearance rules. 4. Click in any one of the boxes in the matrix to change its value. 5. Click OK to apply the clearance rule changes. 6. Click any other button to set default rules for the associated type. 7. Click Close to close the Default Rules dialog box. 8. Click Close to close the Rules dialog box. Table 1-1 lists and describes the rules types:
padslayout_ref英文资料
评论(0)
发评论
下载排行榜
