AMS as3421立体声蓝牙主动噪音消除(ANC)扬声器驱动器
消耗积分:0 | 格式:rar | 大小:0.16 MB | 2017-05-12
分享资料个
  主动噪声消除(ANC)的第一个案例可以追溯到1950,它们最初被用于直升机和飞机驾驶员耳机。根据定义,噪声是一组不同频率和不同体积的混合音调。噪声的不可预知性要求实时处理,这是非常适合模拟为基础的解决方案。
  重要的是要拿起耳朵的噪音,因为相位的噪声是最关键的参数。在理论和实践中,来自不同来源的声波增加了它们的大小,即得到相位错误实际上会产生更多的噪音。得到相位完全正确(与适量的音量/幅度)将完全取消噪音。
  出于这个原因,集中式系统具有非常有限的性能。所有高性能ANC解决方案分别测量不需要的噪音在每个耳朵。
  In feed-forward architectures, the noise pick-up microphones are located outside the ear cup and point typically away from the ear. Noise travelling toward the ear is picked-up before reaching the ear and as it carries on toward the ear, the electronics generates an equivalent inverted signal that it plays back through the speaker. The objective being that the noise and the inverted signal arrive in the ear canal at exactly the same time, with the same magnitude but phase shifted by 180 degrees. The wanted audio signal (speech or music) can simply be added to the anti-noise signal.
评论(0)
发评论
下载排行榜
