1MB的SPI串行CMOS EEPROM的CAV25M01VE-GT3
消耗积分:0 | 格式:rar | 大小:0.12 MB | 2017-09-07
分享资料个
  Description The CAV25M01 is a 1M−bit Serial CMOS EEPROM device internally organized as 128Kx8 bits. This features a 256−byte page write buffer and supports the Serial Peripheral Interface (SPI) protocol. The device is enabled through a Chip Select (CS) input. In addition, the required bus signals are clock input (SCK), data input (SI) and data output (SO) lines. The HOLD input may be used to pause any serial communication with the CAV25M01 device. The device features software and hardware write protection, including partial as well as full array protection. On−Chip ECC (Error Correction Code) makes the device suitable for high reliability applications.
评论(0)
发评论
下载排行榜
