16KB和8KB的串行的CMOS EEPROM CAV25080,CAV25160
消耗积分:0 | 格式:rar | 大小:0.15 MB | 2017-09-05
分享资料个
  Description The CAV25080/25160 are 8−Kb/16−Kb Serial CMOS EEPROM devices internally organized as 1024x8/2048x8 bits. They feature a 32−byte page write buffer and support the Serial Peripheral Interface (SPI) protocol. The device is enabled through a Chip Select (CS) input. In addition, the required bus signals are a clock input (SCK), data input (SI) and data output (SO) lines. The HOLD input may be used to pause any serial communication with the CAV25080/25160 device. These devices feature software and hardware write protection, including partial as well as full array protection.
评论(0)
发评论
下载排行榜
