AAT2605五通道300mA的LDO稳压器
消耗积分:0 | 格式:rar | 大小:1.36 MB | 2017-09-12
分享资料个
  The AAT2605 is a member of Skyworks‘ Total Power Management IC (TPMIC™) product family. It contains five fully integrated 300mA low dropout (LDO) regulators in a small Pb-free 14-pin 3mm x 3mm TDFN package, making it ideal for space-constrained systems. The AAT2605 features low power consumption, low dropout, and high noise immunity from the input power supply. Each channel consumes a mere 30µA of current when enabled, features 250mV of dropout at 250mA and 68dB of power supply rejection at 10kHz. Each channel has its own enable pin and uses a small 1µF output capacitor. Output voltages are factory One Time Programmable (OTP) between 0.6V and 3.7V with 100mV increment and typical regulation accuracy is ±1%. LDO1 and LDO2 share the same input voltage, as do LDO3 and LDO4 while LDO5 has its own independent input. The AAT2605 is a safe solution that integrates an overcurrent limit for each channel and an over-thermal protection. The device is rated over a temperature range of -40°C to 85°C.
评论(0)
发评论
下载排行榜
