cy7c1071dv33 32兆位(2米×16)静态RAM
消耗积分:0 | 格式:rar | 大小:0.46 MB | 2017-09-14
分享资料个
  The CY7C1071DV33 is a high performance CMOS Static RAM organized as 2,097,152 words by 16 bits. The input and output pins (I/O0 through I/O15) are placed in a high impedance state when: ■ Deselected (CE HIGH) ■ Outputs are disabled (OE HIGH) ■ Both byte high enable and byte low enable are disabled (BHE, BLE HIGH) ■ The write operation is active (CE LOW and WE LOW) To write to the device, take Chip Enable (CE) and Write Enable (WE) inputs LOW. If Byte Low Enable (BLE) is LOW, then data from I/O pins (I/O0 through I/O7) is written into the location specified on the address pins (A0 through A20)。 If Byte High Enable (BHE) is LOW, then data from I/O pins (I/O8 through I/O15) is written into the location specified on the address pins (A0 through A20)。 To read from the device, take Chip Enable (CE) and Output Enable (OE) LOW while forcing the Write Enable (WE) HIGH. If Byte Low Enable (BLE) is LOW, then data from the memory location specified by the address pins appears on I/O0 to I/O7. If Byte High Enable (BHE) is LOW, then data from memory appears on I/O8 to I/O15. See the Truth Table on page 10 for a complete description of read and write modes. For a complete list of related documentation, click here.
评论(0)
发评论
下载排行榜
