低电压单和双电源四路SPST模拟开关ISL8391, ISL8392, ISL8393
消耗积分:0 | 格式:rar | 大小:0.33 MB | 2017-09-15
分享资料个
  The Intersil ISL8391–ISL8393 devices are CMOS, precision, quad analog switches designed to operate from a single +2V to +12V supply or from a ±2V to ±6V supply. Targeted applications include battery powered equipment that benefit from the devices’ low power consumption (《1µW), low leakage currents (2.5nA max), and fast switching speeds (tON = 60ns, tOFF = 30ns)。 A 4Ω maximum RON flatness ensures signal fidelity, while channel-to-channel mismatch is guaranteed to be less than 2Ω。 The ISL8391, ISL8392, and ISL8393 are quad single-pole/single-throw (SPST) devices. The ISL8391 has four normally closed (NC) switches; the ISL8392 has four normally open (NO) switches; the ISL8393 has two NO and two NC switches and can be used as a dual SPDT, or a dual 2:1 multiplexer. Table 1 summarizes the performance of this family. For higher performance, pin compatible versions, see the ISL43143-5 data sheet.
.低电压单和双电源四路SPST模拟开关ISL8391, ISL8392, ISL8393
评论(0)
发评论
下载排行榜
