MT7621A编程手册
消耗积分:0 | 格式:pdf | 大小:1336KB | 2017-09-23
jia_ok
分享资料个
MT7621A编程手册
  The MT7621 integrates a dual-core MIPS1004K (880MHz), HNAT/ HQoS/ Samba/ VPN accelerators, 5p GbE switch, 2xrGMII, USB3.0, USB2.0, 3xPCIe, SD-XC. The powerful CPU with rich portfolio is suitable for 802.11ac, LTE cat4/5, edge, hotspot, VPN, AC (Access Control)。 It can also connect to touchpanel, ZigBee/Z-Wave for Internet Service Router and Home Security Gateway. For the next generation router, MT7621 provides several dedicated hardware engines to accelerate the NAT, QoS, Samba and VPN traffic. These accelerators relief the CPU for other upper layer applications.
MT7621A编程手册
评论(2)
发评论
9622315 2017-12-05
0 回复 举报
大量章节都有不同程度的图表删减,几乎没有什么参考价值,这种不完整的7621A手册,网上到处都是。 收起回复
9622315 2017-12-05
0 回复 举报
不是编程手册,而是问题多多,版本老旧的硬件数据手册。 收起回复
下载排行榜
全部2条评论
