R5000F高压整流二极管
消耗积分:0 | 格式:pdf | 大小:283KB | 2017-10-14
王君越
分享资料个
5KV 200MA DO-15封装 插件高压二极管-TAIWAN SUNMATE SEMICONDUCTOR CO.,LIMITED
  Low cost Low leakage Low forward voltage drop High current capability Easily cleaned with alcohol,Isopropanol and similar solvents Case: DO-15, Molded PlasticTerminals: Plated Leads Solderable per MIL-STD-202, Method 208 ! Polarity: Cathode Band ! Weight: 0.40 grams (approx.) ! Mounting Position: Any ! Marking: Type Number
R5000F高压整流二极管
评论(0)
发评论
下载排行榜
