R3000F高压整流二极管
消耗积分:0 | 格式:pdf | 大小:357KB | 2017-10-14
王君越
分享资料个
快速高压整流二极管,3000F 3000V DO-41 500NS
  Low cost Low leakage Low forward voltage drop High current capability Easily cleaned with alcohol,Isopropanol and similar solvents ! ! ! ! ! ! 2500 3000 R2500F R3000F 4.0 5.0 1 of 2 www.sunmate.tw ! Case: D O - 4 1 Molded Plastic ! Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 ! Polarity: Cathode Band ! Weight: 0.34 grams (approx.) ! Mounting Position: Any ! Marking: Type Number
R3000F高压整流二极管
评论(0)
发评论
下载排行榜
