lan83c185芯片低功耗高集成的模拟接口芯片的高性能的嵌入式以太网应用
消耗积分:0 | 格式:rar | 大小:0.77 MB | 2017-10-19
分享资料个
  The Microchip LAN83C185 is a low-power, highly integrated analog interface IC for high-performance embedded Ethernet applications. The LAN83C185 requires only a single +3.3V supply.
  The LAN83C185 consists of an encoder/decoder, scrambler/descrambler, transmitter with wave-shaping and output driver, twisted-pair receiver with on-chip adaptive equalizer and baseline wander (BLW) correction, clock and data recovery, and Media Independent Interface (MII)。
  The LAN83C185 is fully compliant with IEEE 802.3/802.3u standards and supports both 802.3u-compliant and vendor-specific register functions. It contains a full-duplex 10BASE-T/100BASE-TX transceiver and supports 10 Mbps (10BASE-T) operation on Category 3 and Category 5 unshielded twisted-pair cable, and 100 Mbps (100BASE-TX) operation on Category 5 unshielded twisted-pair cable.
评论(0)
发评论
下载排行榜
