高压闭锁三/四路SPDT开关adg5433/adg5434数据表
消耗积分:0 | 格式:rar | 大小:0.41 MB | 2017-10-24
分享资料个
  The ADG5433 and ADG5434 are monolithic industrial CMOS analog switches comprising three independently selectable single-pole, double-throw (SPDT) switches and four independently selectable SPDT switches, respectively. All channels exhibit break-before-make switching action that prevents momentary shorting when switching channels. An EN input on the ADG5433 (LFCSP and TSSOP packages) is used to enable or disable the device. When disabled, all channels are switched off. The ultralow on resistance and on-resistance flatness of these switches make them ideal solutions for data acquisition and gain switching applications, where low distortion is critical.
评论(0)
发评论
下载排行榜
