96ch段驱动点阵液晶显示ST7921
消耗积分:1 | 格式:pdf | 大小:99KB | 2017-10-26
闫錚
分享资料个
ST7920/ST7921数据手册
  ST7921 is a segment driver for dot matrix type LCD display. It features 96 channels with 48 X 2 bits bi-directional shift registers, data latches, LCD drivers and logic control circuits. It is fabricated by high voltage CMOS process with low current consumption.
  The ST7921 can convert serial data received from an LCD controller, such as ST7920, into parallel data and send out LCD driving waveforms to the LCD panel. The ST7921 is designed for general purpose LCD drivers. It can drive both static and dynamic drive LCD. The LSI can be used as segment driver.
96ch段驱动点阵液晶显示ST7921
评论(0)
发评论
下载排行榜
