AMC1203 (Isolated Delta-Sigma
消耗积分:0 | 格式:rar | 大小:269 | 2010-06-01
cherry1989
分享资料个
The AMC1203 is a 1-bit, 10MHz, isolated delta-sigma () modulator with an output buffer separated from the input interface circuitry by a silicon dioxide (SiO2) isolation barrier. This barrier provides galvanic isolation of up to 4000VPEAK. Used in conjunction with isolated power supplies, these devices prevent noise currents on a data bus or other circuits from entering the local ground and interfering with or damaging sensitive circuitry.
The AMC1203 modulator operates from a +5V supply with a dynamic range of 95dB. The differential inputs are ideal for direct connection to shunt resistors or other low-level signal sources. With the appropriate digital filter and modulator rate, the device can be used to achieve 16-bit analog-to-digital (A/D) conversion with no missing codes.
评论(0)
发评论
下载排行榜
