LCD液晶使用说明
消耗积分:0 | 格式:rar | 大小:344 | 2010-06-19
从未拥有
分享资料个
1. Mechanical Specification
2. Mechanical Diagram
3. Interface Pin Connections
4. Absolute Maximum Rating
5. Electrical Characteristics
6. Optical Definitions
7. Optical Definitions
8. Char Display Address
9. Interface to MPU
  9.1 Interface to Z-80 CPU
  9.2 Interface to MC6800 CPU
  9.3 Interface to 4-bit CPU (HMCS43C)
  9.4 Interface to HD6805 MP
10. Timing Control
   10.1 Write and Read Operation
   10.2 Busy flag check timing
11. Initialization of LCM
12. Instruction Set
13. User Font Patterns
14. Icon RAM Data
15. Graph Display RAM Address
16. Software Example
   16.1 8-bit operation(8 bits 2 lines)
   16.2 4-bit operation(4 bit 2 lines)
17. Reliability Condition
18. Function Test & Inspection Criteria
19. Character Generator ROM Map
PAGE 1(LMG-SSC12K64 Serial)
ITEM STANDARD VALUE UNIT
NUMBER OF CHARACTERS 8 CHARACTERS X 4LINES(16*16中文字) --
CHARACTER FORMAT 16 x 16 DOTS --
MODULE DIMENSION 98.0(W) X 60.0(H) X 11.5(T) 98.0(W) X 60.0(H) X 14.0(T) Mm
VIEWING DISPLAY AREA 72.0(W) X 39.0(H) mm
ACTIVE DISPLAY AREA 66.52(W) X 33.24(H) mm
DOT SIZE 0.48(W) X 0.48(H) mm
DOT PITCH 0.52(W) X 0.52(H) mm
LMG-SSC12K64DRG STN,Gray,1/32 Duty,6 O’clock
LMG-SSC12K64DRY STN, Yellow Green,1/32 Duty, 6 O’clock
LMG-SSC12K64DLGY STN,Gray,1/32 Duty, 6 O’clock, LED Backlight
LMG-SSC12K64DLYY STN, Yellow Green,1/32 Duty, 6 O’clock, LED Backlight
LMG-SSC12K64DLGY-E STN,Gray,1/32 Duty, 6 O’clock, E Mode LED Backlight
LMG-SSC12K64DLYY-E STN, Yellow Green,1/32 Duty, 6 O’clock, E Mode LED Backlight
LED Backlight Color Yellow Green
LED Backlight Input DC+5V V 150 mA
Backlight Half-Lift Time 50,000 HR
E Mode LED Backlight Color Yellow Green
E Mode LED Backlight Input DC+5V V 150 mA
E mode Backlight Half-Lift Time 30,000 HR
评论(0)
发评论
下载排行榜
