TRF370x EVM User's Guide
消耗积分:0 | 格式:rar | 大小:678 | 2010-07-08
分享资料个
This document relates to the TRF370x direct quadrature modulator for applications in the transmit path of
base stations and communications equipment. The quadrature modulator is used for upconversion of
signals from the transmit chain DAC to the RF power amplifier device. Evaluating modulator complex
performance involves careful bias-voltage setup, an LO signal, and two differential (I/Q) signals at the
input of the modulator. This document describes the wide range of test options available and the factors
that must be considered in using this EVM
评论(0)
发评论
下载排行榜
