基于IR2101最大功率跟踪逆变器的设计
消耗积分:0 | 格式:rar | 大小:949 | 2010-11-23
胡秋阳
分享资料个
为解决直流逆变交流的问题,有效地利用能源,让电源输出最大功率,设计了高性能的基于IR2101最大功率跟踪逆变器,并以SPMC75F2413A单片机作为主控制器。高电压、高速功率的MOSFET或IGBT驱动器IR2101采用高度集成的电平转换技术,同时上管采用外部自举电容上电,能够稳定高效地驱动MOS管。该逆变器可以实现DC/AC的转换,最大功率点的跟踪等功能。实际测试结果表明,该逆变器系统具有跟踪能力强,稳定性高,反应灵敏等特点,该逆变器不仅可应用于普通的电源逆变系统,而且可应用于光伏并网发电的逆变系统,具有广泛的市场前景。
Abstract:
 To solve the problem of DC-AC inverter, and to utilize solar energy more efficiently, the design of maximum power point tracking inverter based on IR2101 was achieved with a high-performance, which can make the system output power maximum. SPMC75F2413A was adopted as main controller. IR2101 is a high voltage, high speed power MOSFET and IGBT driver. It adopted highly integrated voltage level transforming technology, and an external bootstrap capacitor was used, which could drive MOS tube efficiently and stably. Many functions are achieved in the system, such as DC/AC conversion, maximun power point tracking, etc. The actual test result shows that the inverter system has characteristics of strong tracking ability, high stability and reacting quickly. The design can not only be used in ordinary power inverter system, but also be used in photovoltaic power inverter system. The design has certain marketing prospects
评论(2)
发评论
TM2008 2015-04-02
0 回复 举报
深圳市天微电子有限公司,是一家集IC设计、封装、测试、销售为一体的国内本土集成电路IC原厂,联系人:刘先生 134 1024 2685  Q Q:2692 199 558.
TM2101:是一个高压半桥驱动IC,可快速驱动工作电压达到550V的功率MOS 和IGBT ,具有高端和低端两个通道。广泛应用于无刷电机驱动器、开关电源、逆变器等等。完全兼容IR2101,采用SOP8封装。
收起回复
531994031 2014-08-23
0 回复 举报
好东西 多多分享支持 收起回复
下载排行榜
全部2条评论
