SA58641 pdf datasheet
消耗积分:3 | 格式:rar | 大小:126 | 2008-10-18
YYXIAO
分享资料个
The SA58641 is a high performance monolithic FM IF system with high-speed RSSI incorporating a mixer/oscillator, two limiting intermediate frequency amplifiers, quadrature detector, logarithmic received signal strength indicator (RSSI), voltage regulator, wideband data output and fast RSSI op amps. The SA58641 is available in 20-lead SSOP (shrink small outline
评论(0)
发评论
下载排行榜
