This Recommendation describes the means of interconnecting digital television equipment operating on the 525-line or 625-line standards and complying with the 4:2:2 encoding parameters as defined in Recommendation 601. Part I describes the signal format common to both interfaces. Part II describes the particular characteristics of the bit-parallel interface. Part III describes the particular characteristics of the bit-serial interface.
