MK2703 pdf datasheet (PLL AUDI
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-24
张静
分享资料个
The MK2703 is a low cost, low jitter, high performance
PLL clock synthesizer designed to replace oscillators
and PLL circuits in set-top box and multimedia
systems. Using ICS’ patented analog Phase Locked
Loop (PLL) techniques, the device uses a 27 MHz
crystal or clock input to produce a buffered reference
clock and a selectable audio clock.
ICS manufactures the largest variety of Set-Top Box
and multimedia clock synthesizers for all applications.
Consult ICS to eliminate VCXOs, crystals and
oscillators from your board.
评论(0)
发评论
下载排行榜
