IMP811/IMP812 pdf datasheet (P
消耗积分:5 | 格式:rar | 大小:333 | 2008-11-29
郑成枝
分享资料个
The IMP811/IMP812 are low-power supervisors designed to monitor
voltage levels of 3.0V, 3.3V and 5.0V power supplies in low-power
microprocessor (μP), microcontroller (μC) and digital systems. Each features
a debounced manual reset input. The IMP811/812 are improved
drop-in replacements for the Maxim MAX811/812 with extended
temperature specifications to 105°C.
A reset signal is issued if the power supply voltage drops below a preset
threshold and is asserted for at least 140ms after the supply has risen
above the reset threshold. The IMP811 has an active-low output RESET
that is guaranteed to be in the correct state for VCC down to 1.1V. The
IMP812 has an active-high output RESET. The reset comparator is
designed to ignore fast transients on VCC .
Low power consumption makes the IMP811/IMP812 ideal for use in
portable and battery-operated equipment. Available in a compact 4-pin
SOT143 package, the devices use minimal board space.
评论(0)
发评论
下载排行榜
